Evo warm up
It doesn't hurt mine. Sometimes I'll fire it off and turn off the choke then give a little throttle lock to hold it just above idle to warm up.
I guess I should add....my warm up last only as long as it takes to put my gear on. I usually take it easy the first mile or two when it's a cold start.
On mine, I only pull the choke if it's relatively cold out (like maybe below 60 degrees or so). Otherwise, it doesn't need it.
When you do use the choke, I think it's best to push it back in pretty much as soon as the bike starts. Use the throttle lock to keep the idle up if necessary.
From a cold start, let it warm up enough to where you start feeling the cylinders heat up before you get on it.
JMHO, YMMV, etc, etc, etc.
guido4198 (10-13-2021)
Received 47,744 Likes
Warm up?! Good grief. I've owned my 1990 Glide from new and just start it up, put my gloves on, perhaps ease the choke off a little, then ride off, taking it easy for a short while. It might cough or hesitate a little, but soon clears it's throat and is away. Don't wrap the darned things up in cotton wool!
Like 0maha says, my '91 requires full enrichener on Winter mornings. Then I only use it to get started, and set the throttle-lock to warm up. The only experience I have of having the enrichener on for a long period of time fouled the plugs. That happened early in my ownership and now I only use the 'choke' (if you will) when the bike won't fire otherwise.
Alan
Alan
Springerpilot (11-04-2021)
