EVO Resurrection - Rotor / Ignition Question...
Old 06-24-2016, 02:42 PM
happyhab's Avatar
happyhab
happyhab is offline
Default EVO Resurrection - Rotor / Ignition Question...
I finally found a used engine to put into my bike.
I have a question about the rotor and ignition. See pictures.
The PO robbed the rotor off the used motor I bought. He got it from a friend and it has sat on the shelf for a year and I don't think he even knew it was missing. I'm working on a new wiring harness for the 8-1100 which came with the engine (hence my discovery of the missing rotor).
The other ignition is the 8-2100 that was on my original engine, now exploded. The rotor P/N 32402-83, is the rotor from my exploded engine and checking the HD parts manual, it is stock for my '95 FXDWG.
I noticed that 8-1100 unit has one pickup on the back while the other has two.
My question is if the rotor (from my old engine) will work with the 8-1100?
Attached Thumbnails EVO Resurrection - Rotor / Ignition Question...-img_4557.jpg   EVO Resurrection - Rotor / Ignition Question...-img_4556.jpg   EVO Resurrection - Rotor / Ignition Question...-img_4554.jpg
Old 06-24-2016, 07:05 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
I think it should work. You could always call S&S and ask. Their tech support is always great.
Old 06-24-2016, 09:05 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
is there a part number on the rotor cup?
Old 06-25-2016, 12:29 AM
Hebrew Battle Rifle's Avatar
Hebrew Battle Rifle
Hebrew Battle Rifle is offline
These will work. Give them a whirl.
Old 06-25-2016, 06:34 AM
happyhab's Avatar
happyhab
happyhab is offline
Old 06-25-2016, 08:58 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Cool
They are just so last century - like chains! We're into belts and electronic stuff now!
Old 06-26-2016, 08:04 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
OMG...Fred Flintstone wants his ignition back!
So one module is for a single fire setup... do you have single fire or duel fire coils?
Old 06-26-2016, 08:16 PM
happyhab's Avatar
happyhab
happyhab is offline
Crane Cams single fire high intensity Coil 76-04
Old 06-26-2016, 11:44 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
Okay, So if you have a single fire coil (which that coil definitely is) then you should match it up with the single fire module, which is the 8-2100.
Crane HI-4 Dual Fire Ignition # 8-1100
Crane HI-4 Single-Fire Ignition System # 8-2100
Here are the instructions for the 8-2100 https://www.denniskirk.com/dk/pdf/in...2/dkh20024.pdf
This link has information on the rotor that can be used with the #8-2100 module http://www.retrocycle.com/CustomChro...n_Systems.html
So in theory the rotor you have there should be good to go!
Old 06-27-2016, 04:46 PM
happyhab's Avatar
happyhab
happyhab is offline
Thank you.
Quick Reply: EVO Resurrection - Rotor / Ignition Question...
