Mikuni HSR42 jetting 1998 evo
Old 06-26-2016, 03:33 PM
jcsurf's Avatar
jcsurf
jcsurf is offline
Default Mikuni HSR42 jetting 1998 evo
I'm having a jetting problem with my 98 evo. It has Hillside stage 2 heads, woods 8 cam, Dyna 2000 ignition module on curve 3 and a Mikuni hsr42 with 165 main, 20 pilot and the stock needle in the middle position and the accel pump is set out of the box. It starts easily and warms up quick, runs real good and seems to be getting pretty good mpg ( I'm only on my second tank full with 250 miles on it ). When I roll on the throttle easy it takes off great but when I wack it open from say around 50 mph in 4th gear it stumbles for a second or two then clears up and goes like hell. Before I start tearing into the carb I wanted to get some opinions from you guys on here. BTW the spark plugs look good and are not sooty, kind of a gray color. Thank guys.
Old 06-26-2016, 05:59 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
Not sure what exhaust your running.. or breather.. adjust the air adjustment screw.. when hot,try small increments.
Old 06-26-2016, 06:56 PM
jcsurf's Avatar
jcsurf
jcsurf is offline
Sorry about that, I got a rb racing pro stock 2-1, big sucker intake and the air screw is approx. 1 1/2 turns out. It idles good just stumbles when the throttle is wacked open as I stated above, thanks.
Old 06-27-2016, 02:50 AM
piperbob's Avatar
piperbob
piperbob is offline
try adjusting the accel pump.
Bob
1997 Heritage
Don Panfil (04-29-2021)
Old 06-27-2016, 07:22 AM
jcsurf's Avatar
jcsurf
jcsurf is offline
Should I increase the pump shot or back it off?
Old 06-27-2016, 01:20 PM
piperbob's Avatar
piperbob
piperbob is offline
get the tuning manual and the section on accell pump
Bob
1997 Heritage
Old 06-27-2016, 03:39 PM
jcsurf's Avatar
jcsurf
jcsurf is offline
I have the tuning manual and it doesn't go over specific symptoms.
Old 06-27-2016, 03:43 PM
glidein wide
Try increase first..
Old 06-28-2016, 09:25 PM
mrlexus's Avatar
mrlexus
mrlexus is offline
Adjust the pump cam so that there is basically no gap between it and the rod. Make sure it's squirting gas to around 3/4 throttle, by adjusting the little screw by the top cover. Also make sure it's squirting in the center of the manifold.
Old 06-30-2016, 07:34 AM
jcsurf's Avatar
jcsurf
jcsurf is offline
I switched my dyna 2000 to curve 2 and gave it 2 turns more accel pump shot, seems to have cleared the problem up. Thanks guys.
jcsurf
EVO
29
04-15-2017 07:37 PM
arkmark
09-27-2014 09:24 AM
OB1
General Topics/Tech Tips
11-08-2011 08:45 AM
roadhawg
EVO
06-30-2010 06:59 PM
druminharley21
08-20-2008 11:46 PM
Quick Reply: Mikuni HSR42 jetting 1998 evo
