They told me to ask in the EVO section
You probably can't see into your tank (under tranny). Change oil and filter, put 2 1/2 to 3 quarts in or what your manual says for oil and filter change amount, see where it registers on the dipstick and use that as a baseline....check cold then check hot on stand to see if there is a difference. If you get it too full it will blow it out of breather or breather hoses, don't panic, it will quit and when it does, use that level on dipstick as full level.
Received 4,317 Likes
If that is how your owners manual tells you check your engine oil then that is how you check your engine oil.
Me? I never bother with the dipstick at all.
The reason that the MoCo specifies "upright and level" is that there are a lot of variables that occur if you check the oil on the sidestand. Is the floor level? Is your sidestand bent? Have you lowered your bike? Any of these will cause the level to vary. If I was writing the owner's manual, I'd want to eliminate these possibilities.
Yet another reason why the softail is the best model!!!!!!
Got it all figured out now. Just below the fill spout standing up equals the circle on the dipstick on stand, so I figure I'll check on the side stand and keep it some where between tip and circle. It's just easier on the stand I agree. As far as the bike not being exactly level, as stated before its just an oil bag so give or take a bit as long as it's not overfilled, or so they tell me.
