Possible throw out bearing or worse ?
So I've been having random clutch slipping for the last couple weeks .. I've adjusted the clutch both at clutch basket And cable twice and it's not holding adjustment .. Cable is fairly new , all fluids are fairly new .. Bike will ride fine then out of now where clutch will slip .. I pull in clutch , let it out and it's fine ... Well tonight when riding I noticed my clutch lever would feel tight when pulling it .. Then next shift , it had a good 1/2" slack in it ... Then two or three shifts later the lever is tight again ... ?? Any help is greatly appreciated "96 evo roadking "
I agree something is not letting the clutch return reliably, as you surmise in your 'throwout bearing…' title. Verify there's no issues with the cable/perch/lever and cable path. I don't believe you'll know where the problem is for certain until you remove a cover or two and make a close inspection.
Alan
Alan
I suspect the pressure plate is not returning to proper position at times. Could be binding also check the spring diaphragm (for cracks) . You never mentioned how many miles and if clutch is original or not...You can inspect it all through the derby cover. If all that is good then you will need to check the ramp for wear and the possibility that a ball didn't fall out or is not allowing the ramp to return all the way, should be 3 there.
Received 4,317 Likes
Do you have too much slack in the cable? If so, the feral may be popping out of the slot at the lever. If it pops out and catches on the outside lip, this effectively tighten the cable and can give the symptoms you describe. Also ramp/***** can wear and hang up a bit, not return fully. As other have said, inspect the entire clutch assembly.
Good luck.
Good luck.
Well i only had time today ti take off exhaust and remove right side cover .. Everything seems to be ok.. Clean inside ..No shavings or broken pieces I could find .. The bearing seems fine and the 3 ball/ramp mechanism seems to be working correctly when clutch is pulled (does sit in there a little loose .. Normal?) with pressure on plate it moves inward toward rod..when clutch is pulled it .. .. I assume this is correct and puts pressure on clutch rod ... I'll have to open up primary and take apart & inspect spring/clutch discs when I have more time .. Thanks to all the help
