Push Rod Oil Leak
Received 4,317 Likes
OTOH, a good set of rocker box gaskets (middle and top) will run about $60 (at least that's what I remember paying back in '12). Then there's the labor involved in draining/removing the tanks, dismantling and reassembling the rocker boxes and the rocker arms, and the chances that you might do something wrong there, or end up; with another leak where you didn't have one before, and have to do it over again.
Yes, I know the disadvantages of adjustable push rods, but I've been running them on my otherwise stock motor(s) for 175,000 miles now with none of the issues you mention. The DO make periodic changes of lifters and cam bearings (or trying new cams) a snap. At my age, I like to make things easy on myself.
Cutting and gluing an O-ring? Now that's something even I wouldn't try.
It does happen.
I would try the first option. I worked for 30 years in the oil and gas field, and I have cut and super glued o'rings to use on wells when I didn't have the right size that I needed. If that didn't work, I would go to option 3.
I do my own work, and my labor is free to me.....
I've done it on my shovelhead with the cork ones...cut at a 45 degree angle..did not use any glue and they have been leak free and saves a **** load of time.
Blk/Wht/andChrome (03-05-2020)
Are you sure they weren't bent out of the box? I had to sort through two or three sets of SE pushrods to cherry pick four that ran straight. The rest were assembled crooked. Yes, I'm on very good terms with the local dealer.
If you could bend four chrome moly pushrods, I can't imagine the flimsy stock aluminum pushrods would have fared any better.
When I installed them I was new to Harleys and a friend helped me.
I didn't even know you needed to check them back then.
Hey guys. I Have a 98 FLHRCI with about 32K. The Motor has never been touched. When I go on a run of a hundred or more miles there is a small pool of oil that shows up. It is coming from the top of the rear push rod and running down the side of the rod cover.
If i have the push rods replaced to change the seals what else should I have done? My plan was to leave it stock since it has never been touched. But you know once I start digging in plans change
So, I would wipe it down. Go on a short ride, and re-check. Might save you some grief and $$. Good luck.
edit: If your 98 Evo is running good, and has enough power for you, I would leave it alone and ride the heck out of it. 98 Evos are the closest thing to perfection for HD. :-)
Received 4,896 Likes
Option 3 all day long. The factory modified the rocker boxes from the Shovels to the Evolution motors just for this (and some other) kinds of leaks. One day job using the shop manual to get it apart, replace the O rings and put it all back together.
No reason to introduce an adjustable anything, adding to future maintenance.
