Push Rod Oil Leak
Push Rod Oil Leak
Hey guys. I Have a 98 FLHRCI with about 32K. The Motor has never been touched. When I go on a run of a hundred or more miles there is a small pool of oil that shows up. It is coming from the top of the rear push rod and running down the side of the rod cover.
If i have the push rods replaced to change the seals what else should I have done? My plan was to leave it stock since it has never been touched. But you know once I start digging in plans change
Received 4,317 Likes
You've got several options, if it's a leaking O-ring.
1. Pop top PR cover off. Slice a new O-ring at 45 degree angle. Take out old one and put in the sliced one (super glue, if you want) and carefully replace PR cover.
2. Cut PRs and buy adjustable ones. Replace all O-rings
3. Pull rocker covers, pull out PRs, and replace O-rings and associated rocker gaskets. No head to take off heads.
Anything else beyond those options get more $$ and time.
Adjustable pushrods are not needed on a stock motor and can bend if you get too much tension on them or the lock nut can come loose not to mention that they cost around $100.
The best way is the way I told you.
It seems to me that cutting an o-ring to install it is an incredibly stupid thing to do.
Yes, I know the disadvantages of adjustable push rods, but I've been running them on my otherwise stock motor(s) for 175,000 miles now with none of the issues you mention. The DO make periodic changes of lifters and cam bearings (or trying new cams) a snap. At my age, I like to make things easy on myself.
Cutting and gluing an O-ring? Now that's something even I wouldn't try.
I do my own work, and my labor is free to me.....
