Head Gasket/bolt advice needed
Here down South we have a saying, "There's no such thing as a stupid question, just stupid people asking questions!" So here I go....
I have a 96' Electra Glide Classic that absolutely HATES head gaskets! Presently on my fourth (yes 4) blown head gasket, two each front and back. After this fourth time my mechanic discovered the rear head bolts had worked loose and were no longer torqued correctly. So now we're having "inserts" done on both the cylinders and going with a 5/16 head bolt.
I'm no mechanical genius by any standards and was wondering if anyone on here had done this and the end result? I LOVE this bike and want to keep it! Runs great (when it does run) and rides like a brand new one. Only 45k on the odometer. So should I trust these inserts or take her in and trade it?
That's a surprise least to me the the studs working loose on that year model.
The motor should have studs in the cases (block if you will) uses screws with internal threads.(nuts) to hold the head to the cylinders with the head gasket between them.
It just sounds like things are not getting torqued right, possibly a warped head. Both heads at once sounds strange. If you are confident of your mechanic then going the insert route sounds like a good way to go.
There are stories about letting an EVO warm up a bit before riding to help minimize head and base gasket leaks. There are lots of folks here with more experience than me by a long shot so I'd bet one of them will chime in soon
WP
WP
moseshoward (07-24-2016)
Received 4,317 Likes
WP
WP
Get some Cometic gaskets and follow their directions for torquing them down.
First, that's a great looking bike. I can see how you would be very frustrated with having 4 blown head gaskets. So, what WP and Hillcountry said are all right on. After the second blown head gasket, and with relatively little miles on the bike, you have to start questioning things.
1. Types of gaskets. Are they MLS (multi layered steel)?
2. Is it being torqued down correctly? New head bolts, lightly oiled.
3. Break in period, although it's hard to re-torque the two inner bolts.
Tell us what gaskets, and torque sequence is being used. Do you ride abusive, like no warm up and WTF throttle upon start up? These things can help diagnose your problem.
Good luck.
Good luck.
WP
WP
Good luck.
Good luck.
We have not heard of a problem with head bolts working loose. I think that given the experience of the people in this forum, that would have come up. There are some occasional problems like studs pulling out of the cases, cases cracking, etc., but not just coming loose all by themselves. If the studs did not pull out of the cases, I think something else is going on.
Anyway, inspect the cases real well for cracks around the stud holes. Some inserts like Timecerts, etc., are a good idea, given your problems. Inspect the heads and cylinders and put it together with proper torque and new studs. People like those Cometic gaskets.
I checked, the standard studs are 3/8, I wouldn't want to use a smaller stud without getting the opinion from more than one Harley mechanic.
I have done this on a Yamaha FJ12 inline four engine, but I used Helicoils and used the same studs.
I'm a little concerned about how much meat (material) there is around the studs. The time serts I'm familiar with require some around it.
Ahh wait second have used then to repair studs on VW bug engines many times. No more meat there than on these engines I think.
"Now according to my friends at the local HD Dealer, this is an occasional problem with older EVO engines, the head bolts working loose. My biggest concern is trusting these new inserts."
This would go along with some older EVOs best I remember ahh 90 -93 years come to mind. Maye be a little earlier even.
Were these OEM gaskets by chance. Most around here would say James or Cometic gaskets. The Indy I went to for parts when fixing my blown head gaskets mentioned they prefer James over OEM. When I asked why he said " They just flat hold up better."
WP
WP
