Need a new front mag
well people hit triple digits on those cheap spoke wheels all the time an I haven't heard of a complaint. I did a quick google search an the big complaint is that if you don't keep them clean an waxed they will rust an peel an don't trust the bearing are set correctly.
The Ultima wheel I am looking at is not chromed but polished. They are billet and CNC machined like the high dollar wheels. As far as the bearings go would be on the mechanic installing them.
last time I had a tire mounted I had a 240 put on a muscle wheel for my 02 V rod an they did it by hand. kinda surprised me but it went on pretty easily. They said they avoid using the tire mounter if possible...there wasn't a tire on it when I took it in though so I don't know if they would have removed an old one by hand.
Received 14,147 Likes
I wonder if it might cheaper to have your wheel refinished.
When I looked at Ultima's site, I noticed they sell what amounts to a reducer for the older smaller axles and that is what is necessary to install it on your bike. That also explains why the listings in eBay ETC specify 2000-2006 models or something like that.
From Ultima's website:
NOTE: Use MW# 33-295 Axle Reducer for 3/4†axle applications
http://www.ebay.com/itm/122058519484...%3AMEBIDX%3AIT
This is a similarly styled alternative at about the same price point.
https://www.ebay.com/itm/121079935192
I like these for around the same price.
https://www.ebay.com/itm/201629011411
The second link I posted is made by performance machine yet are still moderately priced. I like how the rotor side looks
Check the fitment, as I was just doing a quick search before going to sleep.
Have you thought about going with a dual disc setup?
Just so you are not pissed when you get the rim. We have 3/4 taped bearings. These are sealed 3/4 bearings or they could be 1" or even 25mm. Anyway you will need new front wheel axle spacers. Your old ones went inside the dust cup of the bearing. If you have a mechanical speedo like me you will need a now rotor with a notch cut out of it. I had to also cut down my speedo. If you are not doing the work. It could get pricey.
