94 softail
94 softail
Hey guys, Bike started acting up like not getting fuel on highway and slower speeds seemed better, it would run on one cylinder and then back to two and run fine. anyways today same thing however shut off for 1 hr and rode home barely making it. took front plug out and not as hot and little fouled, replaced with new plugs and wires from my shovelhead and wont start now.... put old wires and plugs back on and still wont fire? Seems like out of timing? burbing and fart little bit? it has spark and fuel to carb...going to check adjustment of pushrods,any help or direction to go please? kevin:
Nose Cone ...
Pull the nose cone cover ,(thats on the cam cover) both the out side one and inside one ...and check the timing pick up ...see if there's some goohy stuff leaking out of it ...the stuff they used to seal these units back in the day wasn't that good ...and on these very hot days ...it will run out quicker ....if so the pick up is bad ...that will cause alot of ignition problems ...if it runs fine "sometimes " ...it's not the rod adjustment !!!
good luck !!
good luck !!
Received 14,138 Likes
Received 4,317 Likes
good luck !!
good luck !!
i pulled timing cover and it has crane hi-4 ignition mod. no goo or anything. So what should i suspect? Coil is good i believe cuz i have spark.What about cdi box? so i guess hopefully it is the hi-4 mod if i buy one becouse they arent cheap.is it worth going back to stockdouble fire ig mod and coil? and is it the same cdi box for both? Yes you are right about pushrods, i wanted to check front one becouse had ticking noise up in head area. Thanks
The crane hi-4 cone ignitions were notorious for failing and running on one cylinder......then they would run fine...really wasn't temperature related...mine would go back to running fine on a 100 degree day.
Check you spark again..bet you are not getting it to both cylinders.
hey guys, i put in ultima single fire programmable ignition kit and it fired up nice. static timed so far and runs good. Purchased from Jireh 130.00 and shipped fast. Not sure what all the curves and adjustments are for ad have to hook up voe switch..... thanks again for helping me think a little more....
