Clutch adjustment help needed.
I changed primary fluid and adjusted clutch today.this may be a stupid question but my lever has to go pretty far out to fully engage,I set cable with the spec.1/8" play but I have to let out handle further before it starts to engage.no clutch slip,if I take up more slack on cable thru cable adjuster will that give me a closer grab point or opposite. I'm wondering if my cable has stretched. Thanks
95 RK I just went back out and tightened a turns,1/16 gap,I changed my handlebars to heritage 1-1/2 style a couple years ago and everything fit brakes ,wireing ect. But my braided clutch cable never really fit rite.it seems when I lock the front end or its fully turned it pulls the cable slightly. Im going to get a longer cable its at least 5yrs old now anyway.
I have shop manual,I adjusted clutch properly inside derby cover.
Bike should be cold when you adjust the clutch. Upright and reasonable level.
Loosen the cable all the way, then adjust the pushrod under the derby cover to spec.
Then adjust the cable to 1/8" of gap.
If problem persists, you may have an issue with the clutch ramp. Or you've got the wrong length cable for the bike.
Someone pointed out in another Forum thread the possibility of a bad adjuster thread or lets say rough spot, that made it feel like you bottom out. I know I would redo the adjustment and double check making sure I was truly at tension and not just the threads, back off the appropriate turns, and lock it down. Then adjust the cable, operate it a few times and test ride.
Just curious why the adjustment, general routine maintenance or was there an issue?
