Help with my 93 fxrs plzzzzz!!!!
I think its either bad or got very hot at some point . The epoxy seems to have melted and is running down the plate so i think i will just replace it .
Any suggestions on whitch one to get seeming I have a Dynatek 2000 Digital Ignition System - HD2 (7-Pin Enhanced) DD2000-HD2EP on its way .
Received 4,324 Likes
I run the stock ignition pickup with the Dynatek 2000P on both my bikes.
Turns out when my battery cable broke while running 40+ miles an hour the voltage still being made had nowhere to go. Sooooo it blew out my electric ignition module, The pick up, my headlight low beam, my tail light, my rear brake light, my right blinker rear, my left blinker front and also a bulb on the dashboard. Because all the lights went out I just figured it was something of a fuse or a melted wire or a bad ground somewher. It was not until I actually check the bulbs I found out it was all the bulbs. Unbelievable !!!
Should be back up and in the wind very soon
Let this be a lesson to us all to never forget the basics lol
Thank you all for your help !!!
Ride On
Ride On
