Stator Replacement '88 FXSTC Advice Anyone?
Griz
I've replaced these stators before. Not really a hard job. But the pre-1989 softails require removing the inner primary. That means unbolting the hard to get to starter. That then means maybe removing or at least loosening the oil tank to get at those starter bolts. That's the PIA part. I guess there's just no other way around it. But I will go Cycle Electric 32amp. HD's upgrade only works for 89 and up softails. Now I'll wait for parts to be delivered.
......It's always something!
Received 4,317 Likes
I didn't know the new bikes had 40-50 amp systems.
I can only go off what the Tech at Cycle Electric told me.
How sure are you that the new Softails have a 40-50 amp system??
I don't know about that, I do know that your bike and mine had a 32 amp alternator stock.
This is not exactly your's but close.
You got to be a good mechanic already if you have never done it and have the service manual and tools....The Harley service does not teach you, it just gives spec. to people who know the basics. After market parts on old bikes even require you to measure to make sure all is aligned. Read this....
https://www.hdforums.com/forum/touri...ssues-why.html
It's not the job to learn how to work on Harley. It takes heavy duty tools for the comp nut. Screws tend to stick and break in old aluminum.
I'm not a newbie to mechanical work on Harley's. I owned this bike since it was new off the showroom floor. It still looks new and original. It's not my only bike. I posted because the 1988 FXST/C is unlike any newer bike to work on. It's drive system is unique. One of a kind. The service manual is only little help since some key sections are abbreviated. I was hoping someone had experience removing the specific year 1988 inner primary. I can work my way thru it. But sometimes asking pays off. I've already rebuilt the engine. New oil lines. New wiring. New brakes. All OEM parts. The stator is the one exception to bump the amps.
Tons of people will tell you it is doable without removing the oil tank..and it is easy to get the starter off without removing the oil tank...but getting it back on...without it leaking oil...is difficult at best. The old 4 speed type starter requires more finesse that the newer 89 up starter.
Do yourself a huge favor and completely remove the oil tank...takes 15 minutes if you have never done it before...after the oil tank is out of the way...the rest of the job is a piece of cake...in the long run you will actually save time...because the starter is so easy to install with the tank out of the way.
