Steering bearing recommendations
I am about ready to tear down my 93 Heritage softail's front end and change the steering neck bearings, does anybody have experience doing so and are there any recommendations for the new ones? Are the stock ones good or is something like the aftermarket timken tapered ones better?
Thanks
Thanks
Just out of curiosity, how many miles on your original (I assume) bearings? My first set of steering head bearings started "notching" at 80,000 miles. The replacement set is still good at 121,000 miles. Since they've been in, I grease the bearings (through he grease fitting) at every 5K service.
Its really low, the bike has 21k original miles...its possible they aren't worn out - maybe I just need to tighten the neck bolt - I haven't torn it down yet, but I suspect they are in bad shape as the previous owner rode it around dry and then let it sit in the elements. It had that loose feel to it where it rattled a little, and the slight weave when cornering/decelerating and the tires are balanced well/trued well.
Given the negligible cost of a new set of bearings/races, and the total PITA nature of getting to them (particularly on a faired bike), I'm planning on replacing mine as part of my winter maintenance this year.
Big Red will be around 27k miles by the time winter kicks in. AFAIK, the bearings have never been opened up from the factory.
"May as well".
