New Pipes
Received 4,324 Likes
I have a new idea this morning.
I'm gonna try assembling it without the silicone and see what happens.
Not sure why you are having an issue mounting your pipes. I do know that the only place that you should be applying the high temp sealer is for the cnc machined gaskets where they fit into the pipe... No mesh gaskets are used at the exhaust port. Lose fit the entire pipe first, then tighten the head pipe to the heads lightly shaking the pipe to ensure proper gasket mating. There should be no use of rtv at the slip joint of the front head pipe into the collector. It is machined accurately as to not allow an exhaust leak.... Works very well...
That said I think putting it there is the source of my problems.
I'm gonna take it apart and try again without the silicone.
No matter what I do I can't keep it off that floor board mount.
I'm considering grinding about 1/8" out of the floorboard mount to get clearance.
Anybody got any other ideas??
I love the design!!!!!!!
If it wasn't for hitting the floorboard mount they would be the perfect pipes!!!!
