84 FXR Seems like a dead battery, starter problem
I've read in many places on the internet this same problem but the forums just end without any definitive answers. Hopefully someone can help solve this.
Here's a video of my bike trying to start. It's with a brand new battery and relay. I can start the bike with a jump from a revving car and have tested the charging system at the battery; it's fine. I've had the bike for 2 weeks. It fired up right away when I bought it, let is sit for a day, then fired up again. Let it sit for a couple days then fired up right away. The starter always sounded sluggish. A few days later I went to start it up but the results were similar to the video. All the terminals have been sanded clean and the bike runs well when running.
I've heard that the Bendix gear can wear out so that's my next step. I'll remove the starter today. Please let me know if you have any solutions. Thank you.
Continuity to ground off of the starter lug is not a good thing. It comes to that spot from the solenoid, so that may be an issue. Try swapping the solenoid by the starter or rebuilding the one in there now and see if that cures it.
Check the voltage at that lug while pushing in the button and check the readings you get. Should be over 12 volts.
Griz
Griz
Doesn't sound like a bendix..sounds like the starter is struggling...high compression...mechancaly in a bind...worn out starter.
Pull starter and take to a starter rebuild place and have it tested.
That bike has the hitachi starter which wasn't the greatest when new...aftermarket places like all-***** have much better replacments if you need one.
Regarding how I determined continuity between ground and the starter terminal.
I used the continuity setting on my multi meter. The battery was hooked up but bike was off. I wasn't sure if when the solenoid wasn't engaged it maybe grounded the positive terminal of the starter. I'm going to test it while engaging the solenoid today.
I've done all the tests that are in the 1984 to 1990 service manual regarding the starter and solenoid. The starter test seems simple: measure amps between solenoid and starter. If amps are 75 or less, the starter is good and no further tests are required.
I did them and the amps were 20.
Solenoid tests all came back clean as well. Could someone test to see if their starter terminal is grounded? In my head it doesn't make sense but its not sparking everywhere so I wonder... what the hell do I know?
Here's another video:
Have you tried bypassing the solenoid with a direct connection to the starter? Connect a jumper cable to the starter terminal then touch the other end of the cable to the + battery terminal. If the bike turns over then your problem is probably the Solenoid or a bad cable. I have seen positive cables get so much corrosion up under the insulation that current enough current could not get through. Also even though you have a new battery make sure it is fully charged up. I just got a new battery for the Heritage and before I did anything I put it on a charger.
Badluckbikes (10-20-2016)
I'm confident that I can rule out the battery. I took the starter and solenoid to the fix-it shop. I'll know more in a week.
I did find out that the positive and ground on starters share continuity though.
starter prob
My 86 FLHT had the same exact noise when trying to start and got to where it just wouldnt. I had tried the two relay deal put a new selonoid on it ect. Took starter to a old timer who builds alt/starters and he tore it apart while i stood there. The brushes were worn out and one of the "plates"? that they mounted on was charred. I left it with him and he said he would try to find parts. About three hrs later he called me saying he had found one in his parts stash and took what he needed out of it. The bushings he cut down from some others. This was maybe two yrs ago and it starts right up every since. Bet the brushes
Badluckbikes (10-25-2016)
