Cable Length 14" Apes on 98 Wide Glide
I've never fitted apes, but I have fitted plenty of other stuff. I've learned the hard way that whatever you read on here, your experience is likely to be different! In other words, while you may be trying to get everything to hand, so you can change over while having a couple of beers, you are likely to find something just ain't right. Do this yourself - measure where YOU want cable, lines and wires etc to go and don't rely on someone on the other side of the planet telling you what they used. The only alternative is to buy a set of apes with cables etc from one source - then you can blame them!
Received 4,317 Likes
I didn't like them so I went to 16" bars and had to use 4" over cables for those.
