Pinion Race Wwalking Out?
looking in the service manual this looks like the best option, you might get by with pressing it back but I doubt it would stay. Looks like the work is best done with crank out and by a machinist. That snapring is the thrust washer for the bearings, something caused this..
Chris Sigo (11-18-2016)
So, if the race has "walked" outward, that means the bearing can also walk out as well, since the retaining ring will move out along with the inner race. As an engineer with nearly 40 years experience, you'll forgive me if I say that this seems like a rather poor setup, as you are depending solely on a press fit between the pinion shaft and the inner race to keep everything together.
So I got all the gears out of the way to get a better look at that race and the runout of the shaft.
Gave the race a very gentle tap with a piece of PVC pipe and a rubber mallet.... it slid right back in to place. WTF. I thought those were supposed to be pressed pretty snug on to the shaft.
There's also noticeable movement on the pinion shaft, so at this point I'm splitting open the case and getting the flywheels on a trueing stand. Also looking in to why that race is so loose. Could be the whole assembly is shot.
Received 4,317 Likes
On mine there was too much side play in the connecting rods. The crank was sent to Darkhorse CrankWorks. Once they took the crank apart, they determined that the inner crank bearing was shot and had to put oversizebushings and pins in the connecting rods. The cases were sent to Darkhorse and they repaired the Timken/Main bearing bore as main bearings were loose in case. Darkhorse also line bored and lapped the cases and put the bottom end back together and sent it back to my indy.
Smooth bottom end...but if I had to do it again I'd have gone with the 89 crank and probably upped it to a 96.
brad75raiders
Engine Mechanical Topics
18
05-05-2018 08:45 PM
