Front Brake Light Switch
I've got a '91 FLSTC. I decided to install some beach bars. Everything fit ok, cables, wires...but after I got everything back together I had no brake light, using the front brake.
I took it back apart and found a 1-1/4" x 3/32" spring loose inside the master cylinder perch. I don't see a switch. My MC 'internals' don't look like those in my manual nor like anything I've been able to find online.
The shaft in mine (which the brake-lever pushes and which in turn pushes the M/C piston) has a 'paddle' on it. I'd expect that paddle to push against a switch. But I see no switch. It's not laying on the floor. There are no wires in the perch.
All I can think is there was some type of Harley 'magic' at work, making the brake light illuminate when the lever was pulled, and I let the 'genie' (or whatever the hell it was) out when I futzed around with the bars . If anyone's got an alternative explanation, I'd be much obliged to hear it. I don't even know where to start with this, other than taking everything apart and staring at it some more, hoping for enlightenment...
Thanks,
Alan
Thanks,
Alan
Received 4,317 Likes
AlanStansbery (11-21-2016)
Received 14,144 Likes
^^^ This. It's on the grip portion of the assembly. The small lever that activates the switch is on the brake lever portion.
If you don't get the small lever that is in the brake lever portion of the control aligned with the button in the throttle portion, the brake light won't function correctly. A lot of times, it will cause the brake light to remain on, which (if equipted) will cause the cruise control not to work.
I had this problem on my 93 FLHS, and it drove me nuts for a few days. The best method is to loosen both the grip and the lever portion, and align them, before fully tightening down. You must hold the two parts of the control together, or it will slip out of alignment.
Easier to do, than to describe....
What I've found to work, when putting the switch housing halves together, is to pull the front brake lever in (like you would apply the brakes), while pulling the two halves of the switch housing together. That will allow the brake switch to find it's own alignment without getting caught on the brake lever.
Alan, we're on the internet old chap, you can check details like that using an on-line parts website! The switch is inside your r/h switch assembly.
Providing a little follow-up for someone who might have the same issue, in the future...
I mentioned I'd found a spring (dimensions in the first post) inside the right brake housing. Turns out this spring was part of the brake switch. The spring fits inside a small 'button' (Prot's term). The spring keeps the button in contact with a 'paddle' on the brake lever when the lever's at rest (no brake). When you pull the brake lever, the paddle moves away from the button; when the button reaches its full travel (the brakes are now on) the switch 'trips', activating the brake light. (NC switch). Hope that makes sense. I believe it's accurate.
In my case, the button is nowhere to be found. I must have broken it off when I reinstalled the right-hand controls after replacing the bars. I looked for additional pieces on the garage floor (after I found the spring) but you know how that goes...garage floors are 'black holes'.
As Hack'd surmised, you'd expect the brake light to stay on if the switch button was not being depressed by the brake lever. In my case, I ganked-up the switch so bad it 'thinks' it's open all the time, i.e., it's no longer a switch.
They sell the replacement switch and I ordered a Drag Specialties version from Parts Giant a little while ago. $17.60 with free shipping.
Again, thanks all you guys for the help. It's appreciated.
Alan
Alan
