Fork oil change going disastrously wrong
Received 4,317 Likes
How do you put the plug in when you take the syringe out of the hole???
As soon as you take the syringe off the hole it will start draining.
Not fast I grant you but it will drain.
A handy tool otherwise known as a thumb, then have the drain plug handy, replace the thumb with the plug. As long as you don't the quickness of a sloth, the fluid loss is negligible.
That way sounds like a PITA to me but then I don't have all that stuff on top of my forks like the baggers.
On the other hand changing the engine and tranny oil on my softail is way harder to do than on a bagger so I guess you win some and lose others.
Received 5,388 Likes
That is how I do it on my '96 ... hook the mighty vac to the handlebar valve with the core removed and pump away ... I have to remember to put the plug in the slider not being filled so the other draws the fluid ... I have enough suction that I have a few seconds after removing the fill hose to get the plug in before starting to loose a little oil
