Tapered wheel bearings clearance
0maha (02-17-2017)
Received 4,616 Likes
Black grease - moly, you don't want to use that on a wheel bearing. I only use good brand name synthetic that costs a bit, none of that $1.99 a tube stuff. Lot of the sealed bearings have some clear stuff that looks like vaseline in them, and I'd bet that's why so many of those fail early; I always pop a seal off sealed bearings and check, and more often than not clean them out and put the good stuff in. I'd do that real quick on a new off the floor 2017 Harley's wheels, too. Like you, I like the old Timken tapered much better.
If it's done right, press the wrong side in first and it might not save time and money down the road...
Grease them when you change tires and they WILL pretty much last forever, unlike the "sealed" bearings the MoCo uses nowadays. On my bike, one set was replaced at 128,000 miles. The other wheel was still running the original bearings at 195,000 miles and was replaced only because I built a new set of wheels on NOS hubs.
It's things like this that keep me running my "old" bike.
Moco dealers still stock the spacer washers in different thickness, but I bet that will go away as the inventory gets sold. YD
I agree but also need to ad: Do not power wash near the bearings. Blasting water in there will cause rust. When I bought my Dyna the races had pitting and the rollers didn't look all that great either. I'm blaming a power washer or car wash wand by the previous owner.
I have used a pressure washer a handful of times maybe.
Have gotten caught leaving friends or our farm(as we call it) after a hard rain. With a couple miles of dirt and cliche roads traveled to get out, that can make a MESS.
Got stuck once with the bike still upright. A neighbor came along and pulled me out with a rope on the upper part of the down tubes. I removed the rear wheel to clean the fender and wheel up after I got home that day.
WP
WP
Yes I got stuck having no choice but to ride a road that was freshly tore up and then watered down to keep the dust down by the road crew. To turn around would have added at least 50 miles and we had a deadline.
That was last august. Still finding spots of that caked on baked on chit...My buddy in a cream puff road king would not go over 5 MPH. YD
