Softail Board Scrape
If the bike has a lowering kit on it, take it off.
Your shocks might be adjusted to the lowest ride height. If so, adjust them higher.
I used to scrape all the time with my original shocks. Not only did the shocks suck, they also were set very low.
Long story short I ended up with Works Performance light duty shocks adjusted taller than what most people have. Now it rarely scrapes.
You need to lay on the ground next to your bike so you can understand what is going on. The floorboard itself is hinged but there is also a solid piece underneath that is not but doesn't stick out as wide.
While you are laying down raise and lower the floor board while looking underneath it so you can understand it then you won't be as scared and you will understand the corrective action to take.
Lowering a bike to me is one of the most functionally defeating things a person can do. I understand people like a certain look, but I'd rather ride my bike than look at in the garage or God forbid a trailer.
Is laying on its side going too result in the same parts dragging as when it is in motion? It would seem that speed and acceleration would compress the shocks and produce different geometry than when not in motion.
Also the rear swing arm when standing straight upright should carry a straight line from the frame to the upper swing arm to resemble a hard tale. That was the whole Idea behind the softail. depending on how old the bike is and how heavy you are will make a difference in ground clearance.
And for $100 you can upgrade the front springs with the Progressive kit and when installing make the plug 1/2" longer and use 1 more ounce of 15 weight fork oil. It will firm it up and help to relieve the scraping. But all this does rely on how aggressive you ride....
Received 14,165 Likes
I meant for you to lay down on the ground so you can see underneath the floorboards with the bike still upright.
Do not lay your bike down.
While laying down and looking under there, swivel the floorboard up and down with your hand. Doing this will help you understand what is happening during a scrape and how the stationary parts are in relation to that movement.
I went through a couple of sets of progressive 422's in a short period of time. I had very bad experiences with them but I am the odd man out with that. Works Performance is a lot better shock, but it is also a lot more expensive.
Also check your tire pressure, especially the rear.
I measured the clearance from the frame on the stand. I will have to get somebody to hold it up to measure straight up. On the stand, it is 6 1/2 inches on right and 4 1/2 on left so I will call it 5ish straight up and the top of the frame aligns with the top of the swing arm on the stand. Will check that again too when I get help straighten it up.
Received 4,317 Likes
FWIW I just went and measured mine and the left side is 6.5" off the ground and the right side is 13" off the ground and I have lowered the rears just a little.
I'm thinking you're gonna need fork springs, tubes, and the right size shocks to get your bike back to where it belongs.
If you want I have some OEM rear shocks that you can have for the cost of shipping.
Some one lowered the **** out of that bike!!!!
We must be measuring something different. I am measuring from the bottom of the frame to the ground. Ground clearance on the new softails according to HD is 4.7 inches. I think I am a little more than that and it looks like it is sitting properly.
Thanks for the offer on the OEM shocks. I am leaning towards the Progressive 422s at the moment. But I am not sure there is anything wrong with the ones I have.
What do your boards measure?
Sorg67 (02-21-2017)
Then the only thing I can tell you is slow down.
Softails aren't sport bikes.
If I remember right a softail has a 24° lean angle and a bagger has a 37° lean angle.
FXR's and sportsters will have even more.
I came to harleys off a VTX 1300 and that thing has even less of a lean angle than the softails so I'm good.
You may end up deciding that you need more lean angle for your riding and to be honest you will have to get a different style of bike for that.
