Primary noise
02-22-2017, 11:09 AM
Primary noise
I have a noise coming from my primary. While I'm riding I don't hear anything but when I let off the throttle I'm hearing a whistle sound. As soon as I pull in the clutch, the whistle noise goes away. What are y'alls thoughts on this?
02-22-2017, 11:33 AM
How many miles? Sounds like a loose chain.... Time to pull the primary cover and inspect. Do you have factory service manual? If not get one....
02-22-2017, 12:13 PM
25k miles I tightened the chain and it got a little better. But it's still there.
02-22-2017, 12:28 PM
inner primary bearing, or transmission mainshaft needle bearing
02-22-2017, 02:23 PM
Any way to diagnose one from the other?
02-22-2017, 03:21 PM
Got any oil leaks? If the inner primary bearing is shot, that seal is usually shot too. Same with the transmission bearing.
02-22-2017, 03:51 PM
02-22-2017, 05:20 PM
When mine did that it was a transmission main shaft bearing starting to go out.
02-22-2017, 09:35 PM
Definitely what I am afraid of bro. How did you diagnose it was that and not the inner primary?
02-23-2017, 06:30 AM
Quote:
Originally Posted by
Khshockey44
You have to start taking things apart and have a look.
