ultima 53-645 wiring
Old 07-20-2018, 08:05 AM
richard567's Avatar
richard567
richard567 is offline
Default ultima 53-645 wiring
my crane hi4 took a dump(pos), friend gave me a 53-645,early model single fire ultima is no help,they only show the 644 programable..any help?
Old 07-20-2018, 10:45 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Have you called Ultimas tech line?
Old 07-20-2018, 04:09 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,679 Likes on 850 Posts
Old 07-20-2018, 07:00 PM
1997bagger's Avatar
1997bagger
The 645 is the old pre-set big cube module, it will be set for little timing advance, see if the wire colors are the same as the 644 in the wiring diagram, they should be the same. The factory preset module in a 127 has the same wire colors as a Ultima 644
Old 07-21-2018, 09:55 AM
Rob85WG's Avatar
Rob85WG
Rob85WG is offline
Check to see if there is a bank of switches under the label. I've heard Ultima covered the switches on ignitions sold with their performnce engines.
Old 07-24-2018, 07:55 PM
richard567's Avatar
richard567
Default thanks to everyone
I ended up puttin the old work horse stock ignition back in...
geronimo73
EVO
08-13-2020 02:33 PM
Steve UK
Electrical/Lighting/Alarm
01-08-2019 07:29 AM
Moonwinks
09-08-2018 01:25 PM
dutcharoo
05-23-2011 11:52 AM
tagreen2000
10-08-2009 08:53 AM
Quick Reply: ultima 53-645 wiring
