Turn Signal Flasher?
Old 10-28-2007, 09:44 PM
Greybeardrider's Avatar
Greybeardrider
Greybeardrider is offline
Default Turn Signal Flasher?
I have an '87 flhtc, and the signal lights don't blink, the lamps are ok, it's just that if I push the button, they will not start blinking. I have to do it manually. Is there a flasher located somewhere? Like inside the fairing, maybe?
Thanks for any help.
Old 10-29-2007, 01:40 AM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Default RE: Turn Signal Flasher?
I don;t know when they changed but on my 78 Shovel FXS Lowrider the button had to be held pushed in for as long as you wanted the lights to flash.
Old 10-29-2007, 08:22 AM
Locutions's Avatar
Locutions
Locutions is offline
I own an '85 FLTC and the circuit flasher is located in the dashboard area under the speedometer/tachometer. Remove the two screws that hold the top of the dashboard, unscrew the speedo cable, disconnect the wire harness and the directional flasher(s) will be in your lap. Theflashers are not obsolete and still available from the dealer. Also, check the flasher "circuit breaker", wiring and ground for defects.
-M
Old 10-29-2007, 09:23 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is online now
Received 2,707 Likes on 1,343 Posts
85's are going to be different as they have that different dash that's part of the fork/bars.
If you pull the headlight off (1 screw for the trim ring, then the screws around the bucket), you should be able to see the relays underneath the radio. You may have to pull the faring off to actually get to them. I don't know which one is the flasher offhand, but I'm going to guess it is one of those.
Old 10-29-2007, 01:18 PM
Locutions's Avatar
Locutions
Ooops! my bad, you're right about the dash being different...
Old 10-29-2007, 04:47 PM
Vinnie85FXWG's Avatar
Vinnie85FXWG
Vinnie85FXWG is offline
Your flasher unit took a dump on you. I don't know about your bike, bike my flasher unit was located under the seat...
Churchlol
06-05-2017 07:14 PM
scorpion65
Electrical/Lighting/Alarm
08-16-2016 10:16 AM
FlyingSkeet
2014-2023 Touring Models
14
04-01-2016 08:01 PM
cabledude
09-29-2008 09:57 AM
roadhawg
12-20-2006 12:26 AM
Quick Reply: Turn Signal Flasher?
