SE air cleaner
Old 11-15-2007, 11:30 AM
Bama Harley's Avatar
Bama Harley
Bama Harley is offline
Default SE air cleaner
SE air cleaner vs. stock air cleaner setup....What's different? I just had the cam changed to the EV27 and the shop told me that the SE air cleaner would work very nicely with the new cam and that the improved air flow from the filter would really wake up the new cam. Would it be that noticable of a difference?
Is the packing plate basically the same and only the filter different?
Where's the best place to buy the SE air cleaner kit (if the complete kit is actually needed)?
Thanks in advance.
Old 11-15-2007, 02:46 PM
fxstcguy98's Avatar
fxstcguy98
fxstcguy98 is offline
Default RE: SE air cleaner
You got your barries above your twig, you did a stage II before doing stage I? Of course the SE air cleaner will benefit you. Are you running stock mufflers too? Most likely you will have to rejet it after the SE aircleaner is installed. That cam, SE intake and good pipes should gain you 5 to 10 hp over stock, definitly feel it with the butt dyno.
Old 11-15-2007, 03:32 PM
Bama Harley
We'll I had a lifter go bad and had to change the cam/lifters. So, I figure I'd go with theEV27 while it was apart.
What is different about the SE air cleaner? Is it just a free flowing filter element? Or is the backing plate different as well? Where is the best place to buy the SE air cleaner?
Old 11-15-2007, 03:59 PM
extech's Avatar
extech
extech is offline
The SE(hi-flow) type eliminates the air box letting in more air,also a free flow element is included with the kit. They're available at the HD dealer part number 29543-99B
And you will need to rejet.
Old 11-16-2007, 12:01 PM
fxstcguy98's Avatar
fxstcguy98
You could easily get a K&N filter element, thencut out the backing plate between the outside of the element and the edge of the housing. That basically what the SE air cleaner is. A roto zip tool or a dremel with a roto zip blade will make short work of it, but you could do it with a drill or a cutting wheel. Remove as much as you can without wrecking the structural integrity of the backing plate. If you have stock mufflers, get some better flowing ones and then re-jet and hang on. That's the cam I got in my bike too.
Old 11-16-2007, 01:42 PM
mp's Avatar
mp
mp is offline
Zanotti's, Hale's, Chicago HD sell Harley parts for 20% off.
Old 11-16-2007, 02:35 PM
Harley_Dude's Avatar
Harley_Dude
Harley_Dude is offline
Get a SE or Arlen Big Sucker. Your bike needs it.
schumacher
Screamin Eagle CVO Models
03-27-2009 09:01 PM
DBH6601
03-10-2009 11:25 AM
Sreynold1
04-11-2008 10:27 PM
nnfs
06-26-2006 09:27 PM
traveler
Exhaust System Topics
06-22-2005 01:04 AM
Quick Reply: SE air cleaner
