Need info on Hayden oil fix for EVO
Old 04-16-2008, 07:40 AM
lesgf's Avatar
lesgf
lesgf is offline
Stage II
Default Need info on Hayden oil fix for EVO
I read a posting about fixing the base gasket leak using something called the Hayden brass oil "jets" fix. I can't seem to find a location on the internet to see pictures of these brass fittings that go in the crankcase oil feed holes or find a place to buy them. Any help pointing me in the right direction would be appreciated. Thanks!
Old 04-16-2008, 09:18 AM
paco's Avatar
paco
paco is offline
Default RE: Need info on Hayden oil fix for EVO
lesgf
here is where i bought mine,
http://www.parts123.com/parts123/yb....hPage~cadegfea
type in hayden oil fix for product description
here is a write up on this forum,
https://www.hdforums.com/m_123828/tm.htm
here is the web site,
http://www.haydensm6.com/tof_single.htm
Google searchis a wonderful thing........................
later...............................
Old 04-16-2008, 10:51 AM
pistole's Avatar
pistole
pistole is offline
Old 04-16-2008, 08:12 PM
lesgf's Avatar
lesgf
lesgf is offline
Stage II
Thanks!
Old 04-17-2008, 06:28 AM
kiwidave2's Avatar
kiwidave2
kiwidave2 is offline
good bit of kit.
but be *VERY* careful not to drop that little brass grommet into the cases. It is not magnetic.....................
Old 04-17-2008, 08:27 AM
miacycles's Avatar
miacycles
miacycles is offline
We use the "pig Tails" and they work well.
Old 04-17-2008, 01:02 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,675 Likes on 1,094 Posts
V-Twin part#16-0911 is a kit that you use a tap to thread the jugs and nipples that screw into them. No way they could leak then (unless you forget to put gasket on)Most aftermarket shops carry (can order) V-Twin parts
delpster
09-07-2012 06:04 PM
HarleyTony
Oil Archive (no new posts)
07-13-2012 04:47 PM
loxley
07-10-2011 01:36 PM
rocky6068
Exhaust System Topics
01-25-2009 09:55 AM
Tuffluck
Shovelhead
09-13-2007 12:08 PM
Quick Reply: Need info on Hayden oil fix for EVO
