S&S vs. Mikuni
RE: S&S vs. Mikuni
ORIGINAL: Harley_Dude
Mikuni, the 45mm is for large displacement. Make sure it's not overkill on yours.
RE: S&S vs. Mikuni
Mikuni has better response and pick-up. Both have to be taken off to fine tune but if you pay dyno time the Mikuni is the way to go ............. deciding factor for me was initial starting and flatslide throttle pick-up off the line ........... HSR42, 75% are OK from the box.
RE: S&S vs. Mikuni
Mikuni's are not hard to tune!! Just read the manual follow the steps and you will be OK. Most are just slightly rich out of the box. Bolt it set the accelerator pump as it can give you a false rich reading then check the plugs and follow the instructions. Or take it to your nearest bike meet that DR. Dyno will be at and he will get your pig flying!!!!!!
RE: S&S vs. Mikuni
I have an S&S E on my chopper. I don't notice the low RPM sluggishness some of the heavier bikes seem to have. It may have less pulling power below 2000 rpm but the rollon from 50 mph(2500 rpm) to 100 is phenomenal. If it accelerated any harder I wouldn't be able to hold on. I can't vouch for the Mikuni, but I just love blowing by the front fender of semis, passing their rig at 100+mph.
