1991 FXR Evo breather(s)
I've just fitted an Andrews EV27 and an S &\\; S super E carb to a 1991 FXR Evo engine. Its fitted with a crankcase breather and when I mounted the carb I noticed the heads are tapped for head breather(s) as well (fitted with solid bolts). Question is can I fit two breathers or connect the crankcase &\\; head breather to one filter or plumb both or none (seperate remote filter) to the air filter housing ? Would two breathers be overkill ?
RE: 1991 FXR Evo breather(s)
Andre,
Responded to your \\;e-mail. If you do not understand \\;just get back to me with the specifics and I'll try to help. I was quite surprised to see that you installed the package so quickly, Good Job !! BTW, Did you swap the ignition module out?
I didn't think 91's came with breather holes in the heads. I thought those heads started in 92 with bottom breather \\; but no provision for breathing. On mine i have a screaming eagle breather bar between the bolt holes and run it back to the carb. I had a problem with alot of my oil coming back out through the carb. I needed rocker gaskets and the umbrella valve came with so i put them in and my oil consumption went down and no more oil down the side of my bike. \\;I would check and see what part numbers those heads are and see if someone changed them out to a newer set. Just out of curiousity. Kent
