1986 FXR transmission question
Old 07-11-2008, 12:09 PM
Zzyzx's Avatar
Zzyzx
Zzyzx is offline
1st Gear
Default 1986 FXR transmission question
I have an 86 FXR thats going to need transmission work.&nbsp\\; And in my search for possible upgrades for it, I was told that it would be a good long term fix if I were to update the transmission from the Tapered shaft to the newer Spline shaft.&nbsp\\;&nbsp\\; Given that apparently the Tapered shaft can crack the clutch housing over time.
anyone hear of such a conversion or have done it?
Old 07-11-2008, 12:39 PM
js124's Avatar
js124
js124 is offline
Default RE: 1986 FXR transmission question
you can do it . you will have to change the cluych basket and all that out also
Old 07-11-2008, 01:35 PM
Zzyzx's Avatar
Zzyzx
Zzyzx is offline
1st Gear
Is it as simple as picking up a 90's main shaft?&nbsp\\;\\\\\\; &nbsp\\;\\\\\\; or would I be using the gear set too?&nbsp\\;\\\\\\; and if it is just updateing it to a 90's FXR's gear set &amp\\;\\\\\\; main shaft, does that mean any 90's FXR transmission would fit the housing?&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\ \\; Basically I'm asking if the only difference between the 86-90's transmissions are the taper vs spline main shafts.
Thanks again!
fxrer
EVO
08-01-2015 09:33 PM
DBLJ
EVO
28
06-01-2011 04:16 PM
Jpdyna
EVO
03-12-2011 12:10 PM
GeorgeF
Classic HDF Photos
01-01-2009 07:54 PM
IlDuce
All Other Models
10-25-2008 06:36 PM
Quick Reply: 1986 FXR transmission question
