Help! Harley-Davidson Evo Engine Problem
Old 07-17-2008, 11:40 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
Default RE: Help! Harley-Davidson Evo Engine Problem
And as johntheone says, check your breather too.&nbsp\\; Is the timing OK on it?&nbsp\\; Line not plugged?
Old 07-17-2008, 02:12 PM
jaro's Avatar
jaro
jaro is offline
6th Gear
Thanks Dr.Hess, your hints will be surely useful.
&nbsp\\;
I checked already johntheone&nbsp\\;conception. Breather line is free (not plugged) and timing is OK. /Breather valve is standard (plastic)./
...I have early Evo -&nbsp\\;bottom-breather engine (not heads breathing!). Maybe has someone&nbsp\\;early Evo???
&nbsp\\;
...If piston rings be worn out, then combustion gases get to engine case...
I wonder, or so good static cylinder pressure (about 145 PSI)&nbsp\\;can be near&nbsp\\;worn out piston&nbsp\\;rings???
Old 07-17-2008, 06:47 PM
pococj's Avatar
pococj
pococj is offline
Received 1,206 Likes on 460 Posts
If replacing the seal does not work and there is no obvious crack, expect to find a worn out main bearing, or it is leaking past the race.
Old 07-18-2008, 10:29 AM
Locutions's Avatar
Locutions
Locutions is offline
The issue is likely to be the crank seal...which you cannot replace, the seal is pressed when the cases are made and not repairable... per HD.&nbsp\\; My buddy had a 1990 FLHT with a similar issue.&nbsp\\; Under warranty&nbsp\\;HD fixed the issue with a new cases (parts and labor)...why? because the crank bearing tolerance was manufactured wrong in late '89 and 90 models.&nbsp\\; Therefore, oil will pass into the primary, HD never issued an "out right" recall&nbsp\\;but did&nbsp\\;fix the bikes on an as needed bases.&nbsp\\; The defect was noted in the TSB Feb 1990.&nbsp\\;&nbsp\\;You can call HD (not a dealer...they don't know jack) and they will confirm the issue.&nbsp\\;
&nbsp\\;
To test...pull the primary completely, pressurize the cases with air (don't need alot of pressure) apply soapy water around the crank seal...most likely you&nbsp\\;will see bubbles.&nbsp\\; Although, lets hope&nbsp\\;this is not the problem.&nbsp\\;&nbsp\\;
Old 07-18-2008, 06:44 PM
pococj's Avatar
pococj
pococj is offline
ORIGINAL: Locutions
The issue is likely to be the crank seal...which you cannot replace, the seal is pressed when the cases are made and not repairable... per HD.&nbsp\\;\\\\\\; My buddy had a 1990 FLHT with a similar issue.&nbsp\\;\\\\\\; Under warranty&nbsp\\;\\\\\\;HD fixed the issue with a new cases (parts and labor)...why? because the crank bearing tolerance was manufactured wrong in late '89 and 90 models.&nbsp\\;\\\\\\; Therefore, oil will pass into the primary, HD never issued an "out right" recall&nbsp\\;\\\\\\;but did&nbsp\\;\\\\\\;fix the bikes on an as needed bases.&nbsp\\;\\\\\\; The defect was noted in the TSB Feb 1990.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;You can call HD (not a dealer...they don't know jack) and they will confirm the issue.&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
To test...pull the primary completely, pressurize the cases with air (don't need alot of pressure) apply soapy water around the crank seal...most likely you&nbsp\\;\\\\\\;will see bubbles.&nbsp\\;\\\\\\; Although, lets hope&nbsp\\;\\\\\\;this is not the problem.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;
I think you mean the race.&nbsp\\; The seal is on the outside and is easily replaced.
Old 07-19-2008, 10:27 AM
Locutions's Avatar
Locutions
Ooops! My bad...you are correct Pococj...I mean race.&nbsp\\;
Old 07-19-2008, 01:31 PM
JBaker421's Avatar
JBaker421
JBaker421 is offline
Big Kahuna HDF Member
Just my .02, I'd replace that bottom breather valve first. It may not be the problem but they do go bad, they are cheap and easy. Won't hurt to have a new one anyway.
Old 07-19-2008, 01:33 PM
JBaker421's Avatar
JBaker421
I would also check or replace all of the breather hoses for the h3ll of it. Sometime they can plug up. Even if the breather or hoses don't solve it, it's good cheap maintenance.
Old 07-20-2008, 10:13 AM
jaro's Avatar
jaro
jaro is offline
6th Gear
Hi!
pococj, Locutions
&nbsp\\;
what it marks word: "race", about which you write???
I think you mean the race. The seal is on the outside and is easily replaced.
My technical English is not good...
&nbsp\\;
Have You&nbsp\\;on thought "bearing race"???
&nbsp\\;
&nbsp\\;
Old 07-23-2008, 01:23 PM
Stkman's Avatar
Stkman
Stkman is offline
&nbsp\\;STD can replace the seal and race on your engine case, it's a up grade they do, had it done on my cases (I have a 90 FLH).&nbsp\\; You will need to split the cases and send both&nbsp\\;sides in.&nbsp\\; But before I did that I would make sure nothing else could be causing your problem.
Quick Reply: Help! Harley-Davidson Evo Engine Problem
