Help! Harley-Davidson Evo Engine Problem
Received 1,211 Likes
RE: Help! Harley-Davidson Evo Engine Problem
ORIGINAL: jaro
Hi!
pococj, Locutions
what it marks word: "race", about which you write???
My technical English is not good...
Have You on thought "bearing race"???
Hi!
pococj, Locutions
I think you mean the race. The seal is on the outside and is easily replaced.
Mr. Jaro, the race is the metal sleeve that is cast into the case half, through which the shaft extends out into the primary.
I just went through this with my 89 evo, just a few months ago.
I had just had the entire engine rebuilt, top and bottom.
site is goofy. have to post several times.
Then:
Oil leaked into the primary from the engine. I'm running a belt, so it was a big mess. I had them pull the primary and replace the seal and look for cracks. After they finished, still leaking badly. I found out those years of HD cases had a lot of problems with the races in the case halves. I took it back and they pulled the primary, and this time started the engine and ran it until it got hot, then took a bar and pryed very slightly on the race. It leaked between the race and the aluminum in the case.
Then:
Thanks, Campingout
Know You \\;what OEM \\;number can this part "race"???
I foundling this more then easily in harley parts catalog.
It is also possible that the retaining bolts screws for the regulator harness are leaking .MIne is a 87 and went through the whole seal and etc leak . Someone previously had removed the plastic retainer for harness and siliconed the holes closed , well after a while it leaked . Pain in the *** to find . Only located with engine oil dye . Good luck
ORIGINAL: jaro
Thanks, Campingout
Know You \\;\\\\\\;\\\\\\\\\\\\\\;what OEM \\;\\\\\\;\\\\\\\\\\\\\\;number can this part "race"???
Thanks, Campingout
You CAN replace the individual left crank bearing parts BUT it's a pain to do and set up correctly. Best deal is the pre-loaded bearing from Timken for about 30 bucks. Has all the right matched parts including correct pre-load spacer.
Hope you got the oil leak found.... went through all that myself, first engine oil into the primary then later it was going the other way
Hi, t150vej
Think You \\;replace of new \\;bearing (left side) - OEM 9028 ???
http://www.jpcycles.com/productdetai...rch=oem%209028
[IMG]local://upfiles/68003/6A7BEEB5AAFB4F6F83B77EBA20763BF1.jpg[/IMG]
You won't find an OEM part number for the race, I don't think. It is part of the case half. It is cast in the case when the case is built. The race is not a separate OEM part.
Campingout,
I found figure from repair manual CLYMER.
Part number 5 \\;and 7 is this, about which you write "race"??? (click on Thumbnail Image)
[IMG]local://upfiles/68003/A6E42DFF92164FB6BBEE742E20338559.jpg[/IMG]
