Peace and Quiet with an Evo!
#5861
today I did a general inspection of the fatty tire pressure oil tire wear made sure everything looked and felt right,I did find the pressure in my tires was a bit low.so............................................ .......... I added an ounce of sea foam in each tank waited a few mins. recheck the tire pressures and walla both were back to spec.............................................. now if I had pumpkin cake and english coffee well.............................................. ...............
Well, today, I changed the FLUIDS in all 5 holes but, discovered my KUNUTER valve was plugged with TURN SIGNAL fluid, so, I added FOUR ounces of SEAFOAM before I rotated the air in my tires and WALLAH! All is well again......:icon_rolley es:
#5862
Received 4,317 Likes
My only question is why did you change the fluids if you never ride it past your driveway????
#5863
#5864
#5865
#5866
#5867
if you bibble water is will cause you to have gas
if you lay the pumpkin in your oxter it will give you gas
if you are macrosmatic you will be in trouble
#5868
Thems some mighty fine BIG words you used........
Dood they mean "the smeller's the feller?"
#5869
Too much coffee I think!!!!!!
