Evo Crankcase breather filter. Fit or not?
On my 99 Softail Custom I have the air cleaner nub blocked, and the vent hose going to the bottom of the bike. I do not have any oil comming from the hose as long as I do not fill the oil tank to the full mark. If I fill it to the full mark it will always drip oil on the garage floor when I shut it down and park it. Just me, but I think any restriction in the vent can contribute to engine gaskets leaking.
I also keep the oil level about 1/2 way up the stick, but when I ride steady at 70 to 80 mph, like on the interstate, it still mists some oil.
The tee thing does seem to be the best solution. I may do that also now that I think about it. Most of my riding is done at 65 and below, with up to 80 maybe for a short time. Probably why I do not have any drips. Still, looks to me like the tee will be the best of both worlds. Very good idea.
As I'm running an S&S Super E carb and backplate, I fitted a Drag Specialties chrome crossover (similar to the SE), between my SE heads. Then ran a 3/8" hose down between the engine and transmission, under the transmission and fitted a cleanable filter to the end of the hose. I also installed an S&S Reed valve breather while into the cam chest for a cam change. With those two mods, no more misting, carryover and the carb stays clean.
The Cheap Uggsis the largest distributor of sheepskin footwear.The ugg black Australia story began in 1978 when a surfer by the name of Brian Smith needed a way to keep his feet warm between waves and the Ugg Bailey Boots was born.Every shoe will feel great from the moment you put it on, year after year.
Olias
Engine Mechanical Topics
01-04-2010 06:38 PM
