chaging the fuel filter in the gas tank
Well I did give detailed instructions how to extract it from inside the fuel tank... If they still can't find it, then maybe they should just bring it to some over priced dealer to replace it.
I bet you believe that its unnecessary to replace the fuel filter in a car too.
You are sadly mistaken if you think these gas stations have filters on the gas pumps. I drive for a living and you would not believe some of the garbage I have seen in my primary fuel filter system in my truck.
Let me just say this... It felt like I added 20 HP or more when I replaced the fuel filter. How many hundreds (maybe thousands) of dollars have you spent just to add 10 hp to your scoot like pipes, fuel computer, carbs, ect...
These evos with EFI engines have a filter inside the tank that needs to be replaced every 20K - 25k miles. If nothing else, remove the filter and replace it with one that is better accessible, but just because you don't see the garbage doesn't mean you don't have a problem.
Here is the link from my thread that involved my fuel & Temp sensor issue. Scroll have way down and you will see what the gas looked like that I dumped out of the filter, not the tank...
https://www.hdforums.com/forum/evo-c...m-efi-evo.html
Really....
I've not added thousands of dollars to get extra hp. All my bikes are stock 80 EVO engine. One bike has the Super E, another has the stock carburetor on it, and the EFI has never been remapped either. All bikes have slipon for exhaust the EFI model has the stock exhaust on it. Far from thousands of dollars spent for hp. The bikes have never had a fuel related problem. Not to mention one of the bikes is fairly high mileage.
Diesel engines though....I promise the fuel filter does get changed.
Take it or leave it.....just speaking from my experience. Granted, everyones experience varies as well.
1 Post
I replace the fuel filter for a friend of mine who had a 04 Roadking with about 64000 miles on the original filter. About two weeks later he came over to the house and said the bike was running great, but the bike was using alot more gas than before. I'd be willing to bet his fuel flow was reduced by about 25% with the old filter. Also it makes the fuel pump work much harder and shorten it's life.
