Drive Belt issue
Drive Belt issue
I was doing some maintenance today and happened to take a look at my drive belt. I noticed this line that doesn't go thru the belt, but goes all the way around the circumference of the belt. It looks like the belt has been dragging on something during it's rotation. I can't remember the last time I looked at the belt so I don't know how long it's been that way.
Anyone have any idea what caused this?
Thanks-
C
Thanks-
C
Yeah, it looks like something was rubbing on it. Go over everything looking for something that might be rubbing. Especially check under the covers. Get a mirror on a stick if you have to. It might have been a rock or branch or maybe a screw or bolt on one of the covers, or the lower cover.
I don't think that belt is shot. I would run that belt. The load on the belt is not with that line, so I think the chances of it breaking because of that are slim.
Take your belt guards off for a closer look. Something has either got lodged where it shouldn't be, or come loose. It ain't good, that's for sure! If you can jack the bike up just turn the wheel by hand, and listen for something purring. Best of luck.
I have just replaced my belt after it suffered stone damage, although I did use it for around 4k miles before the wound started to spread out. If you can cure the cause of your damage you can probably carry on riding with it.
Thanks-
C
Thanks-
C
I'll tell you exactly what it is... Mine's been like that for 40k mi and counting.....
Take a look at your transmission vent tube. I'll bet that the hose is piinted down and rubbing the belt, or had been at one time.. Its hard to picture a rubber hose doig that to a belt, but it will. I know first hand.... I'd just move the hose and ride.. It's not damaged..
Thanks for all the replies guys.
I actually solved 2 mysteries today. The first was what was causing the belt damage. The other was where the acorn nut ended up that I dropped off the back of the tank mount when I was putting it back on 3 weeks ago. The nut fell out of my hand and never hit the ground. I couldn't find it and was in a hurry so I just replaced it with a 3/4 nut I had laying around and went for a ride thinking the nut would vibrate off and then thought nothing of it again, until today when I crawled up under front belt pulley and found the nut jammed in there.
It took a little prodding but I finally got it to fall out a hole on the right side of the pulley. The nut looks like it's been bounced around a bit, but I didn't see any obvious pulley damage so I think as long as the belt holds, I'm good to go.
I love it when I win.
No doubt. I have at least a set of small wrenches and sockets lost in the engine compartments of all the cars I've owned over the years. I now have a few great little tools for that kind of thing. None of them worked in this situation, but I'd still recommend having them.
I have a small telescoping mirror and a telescoping magnet and then this 2 foot long metal flexible thing with a pushbutton on the top and a 4 fingered metal grabber thing on the bottom. I don't know what they are called but I'm sure everyone has seen them. All cheap and useful items you can normally find near the registers at autozone and hardware stores.
c
c
Glad you found the prob. Something I learned a long time ago working on helicopters in the Navy is, lay towels around the area your working (think how doctors do it). It catches all kinds of dropped stuff. Oh BTW, "2 foot long metal flexible thing with a pushbutton on the top and a 4 fingered metal grabber thing on the bottom." Those are called Mechanical fingers.
