80 ci evo help
Old 07-11-2010, 07:47 AM
jacko1488's Avatar
jacko1488
jacko1488 is offline
Default 80 ci evo help
i have a 80ci evo. i have oil boiling up out of lifter blocks.
what are some of the reasons this could happen.
i have low compression in front cylinder i was going to deal with it this winter. could this cause the other?
Old 07-11-2010, 08:15 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,689 Likes on 1,341 Posts
I don't know exacly what "boiling up out of the lifter blocks" means. A lot of oil? Some little bubbles? Anyway, an oil leak there could be the lifter block gaskets. How low of compression? Excessive blowby from a blown piston could be pressurizing the bottom end. Either way, sounds like the top end is coming off, and new lifter block gaskets when that happens.
Old 07-11-2010, 08:21 AM
jacko1488's Avatar
jacko1488
yea a lot of oil, 10 miles covered the whole right side of bike.
the compression deal, the bike runs grate thats why i cant see all this going on with it running so well.
what the heck...off with her heads!
thanks
Old 07-11-2010, 03:38 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
Are you sure it is not coming from the aircleaner?
Old 07-11-2010, 05:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,478 Likes on 4,603 Posts
Deleted
Old 07-11-2010, 05:05 PM
Dan89FLSTC's Avatar
Dan89FLSTC
What year?
What model?
Mileage?
Please explain exactly what boiling out of the lifter blocks means.
Exactly where on the lifter block?
Old 07-12-2010, 07:53 AM
jacko1488's Avatar
jacko1488
its a 90 ultra, 48,000 miles. at 50 the oil is pushing up and out of the lifter blocks. a lot of oil, you could see it running. soaked the whole right side of bike. and i did check to make sure it wasnt coming from air filter.
Old 07-12-2010, 08:11 AM
Dynamic's Avatar
Dynamic
Dynamic is offline
Did you check to see if the oil pump is scavenging? What is the level in the tank?
Old 07-12-2010, 01:50 PM
jacko1488's Avatar
jacko1488
oil level is a little low in tank but it did leak alot of oil
Old 07-12-2010, 06:52 PM
96roadking's Avatar
96roadking
96roadking is offline
are the lifter blocks loose?
Quick Reply: 80 ci evo help
