1998 evo
1998 evo
I have a 98 heritage, V&H longshots, SE Air Cleaner and ignition.. It been recently dyno'd. Runs smooth.
Could use more gitty-up though. Tops out around 80-85 mph. Looking for suggestions for the best hop-ups moving forward? My wrench wants to go w/ a S&S Super E, tunable ignition and removle of most of the baffle in exhaust. He wants me to ride it after his ideas than talk cams.
thoughts?
thoughts?
Seems a bit slow to me. how many miles on the motor? Have you done a compression check? The book says anything over 90 PSI hot is okay, but I disagree. A good Evo with stock cam should produce 140-150 PSI hot. If your compression is low, you might want to consider freshening the top end before you think about cams.
