flooded
Old 01-14-2011, 09:57 AM
hotrod351's Avatar
hotrod351
hotrod351 is offline
Default flooded
well i tried to start my bike awhile back. gave it a couple twist of the throttle, enrichment pulled up, nothing. couple more twist of the throttle, still nothing. pulled the plugs = dry. air cleaner off, put hand over the carb to choke, nothing, checked the plugs = still dry. can see gas squirt in carb. good spark, finally left plugs out and bike sit for 5 or 10 minutes, plugs back i and fired right up. first time ive ever seen a motor flooded and not show up on the plugs, any thoughts.
Old 01-14-2011, 10:18 AM
Mike T's Avatar
Mike T
Mike T is offline
That's a new one on me.
Old 01-14-2011, 10:29 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
No!. Best pretend it didn't happen....
Old 01-14-2011, 02:13 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
I almost lost my coffee on the keyboard with that one.
Old 01-14-2011, 02:26 PM
bagga's Avatar
bagga
bagga is offline
when you flood them like that, no choke and hold the throttle wide open. it should clear the flood and start.
Old 01-14-2011, 03:43 PM
miacycles's Avatar
miacycles
miacycles is offline
Never saw "dry, flooded plugs", must be an ethanol thing or maybe you need an Exorcism!!!! Keep us posted if it happens again.
Old 01-15-2011, 10:59 AM
Holster Maker's Avatar
Holster Maker
Holster Maker is offline
I think it wasn't flooded yet, just needed another twist and a slight throttle opening....that right little place and it will start. Every carb motor (usually with 1-2 cylinders) has it's own little procedude to start (depending on weather/other conditions), like my chain saw, weed eater, lawn mowers, race bikes, etc. Once you learn that little trick it will start. My riding lawn mower's motor will not start until I pour gas into the carb, a bunch. You would think it would be flooded, but loves it! No two are a like!
my 2 cents.
Old 01-16-2011, 10:19 AM
hotrod351's Avatar
hotrod351
well i even put my hand of the carb to choke and nothing. anyway it might of just been a freak thing. ill find out today.
Old 01-16-2011, 08:32 PM
Tactical111's Avatar
Tactical111
Tactical111 is offline
Question Idiosyncracies? (sp?)
my 2 cents.
That is so weird. My lawnmower won't start until I pour beer in MY throat!!??? It's always the same every time I mow!!??
On the bike it's choke on then half twist on throttle while it's cranking and BAM it catches.
Old 01-17-2011, 10:23 AM
bparsel's Avatar
bparsel
bparsel is offline
BWAHAHA! My mower must be the same brand of ornery bast@rd as yours!
jgibson79
06-18-2011 11:08 PM
frankjc
Exhaust System Topics
07-19-2010 06:12 PM
mucklepilly
04-09-2010 08:54 AM
adubb1
04-07-2008 04:51 PM
B Will
04-07-2008 12:19 PM
Quick Reply: flooded
