Thunderheader on 80"
Old 04-06-2011, 05:18 AM
Drinkslinger's Avatar
Drinkslinger
Drinkslinger is offline
Default Thunderheader on 80"
I have a chance to pick up a Thunderheader 2 into 1 in almost new condition for a good price ($200). I believe the motor is stock. CV carb w an S&S air cleaner. I have shorty dual drag pipes that came on the bike. Will I notice any difference in performance on a stock motor?
Old 04-06-2011, 08:08 AM
stevelonewolf's Avatar
stevelonewolf
stevelonewolf is offline
With the motor being stock and you have an S&S. What i would be checking is if your rear pipe is shorter than the front. If you ever decide to have performance work done on your motor, It's a lot easier to tune a bike that has the same length pipes. Thunderheader is a good set up and the two pipes go into one collector
Old 04-06-2011, 09:19 AM
Havoc88's Avatar
Havoc88
Havoc88 is offline
Love mine, you see its gains in the top end!
Plus nothing sounds like it!
Old 04-06-2011, 10:35 AM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,625 Likes on 842 Posts
Thunderheader is the best sounding 2-1 and will help now and better later on if you get the "tweak it more" in your blood. Check it close for cracks, it's weakness is other brands 2-1's workmanship is a little tighter, good pipe and they will hear you coming.
Old 04-06-2011, 11:18 AM
Calwoodbutcher's Avatar
Calwoodbutcher
Calwoodbutcher is offline
$200 is a good price. Like 1997 says, check for cracks and the mounting bracket on the collector. I have been running one for a while and like it a lot. The headers do run hot so you will either need sheilds or wrap them.
Old 04-06-2011, 12:20 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
A 2-into-1 should give better performance than any other set-up, especially for road use. Think of the performance gains Buell got using one on their versions of the Sportster motors!
Old 04-06-2011, 07:50 PM
topfuel7's Avatar
topfuel7
topfuel7 is offline
I really like it. I have seen 2 versions. One is for floorboards I think and the rear pipe goes straight down. On the other one the rear pipe swings forward and both pipes wrap around the ignition cone like Havoc's.
http://www.youtube.com/watch?v=Vf8eZTLHuMM
Old 04-06-2011, 10:24 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
I wouldn't run any other pipe.
[IMG][/IMG]
Old 04-07-2011, 01:43 AM
Holster Maker's Avatar
Holster Maker
Holster Maker is offline
I sold mine for $350 (1/2 price), so $200 is a very good price.
I like low-end torque, which it won't have after a few months old. They don't have much back pressure and burn-out too fast causing them to be too loud IMHO!
However, I got mine to work with a glass pack/baffle cut out of a hot rod glass-pack muffler, fit perfect and then it had torque and sounded better.
I sold it because I wanted true duals for that old "separate pulse" sound I missed. I know 2 into 1 is better for performance...hence X pipe, but I'm not racing, just like the old sound.
I now have real good low-end torque, love it!
Old 04-07-2011, 11:22 AM
Drinkslinger
Thanks for the info. I did buy the thunderheader. Gonna put it on sat and see how the carb behaves. I suspect I'll be rejetting. Good thing its still raining.
Quick Reply: Thunderheader on 80"
