Help with derby cover leak
Old 04-06-2011, 10:04 PM
Johnny423's Avatar
Johnny423
Johnny423 is offline
Default Help with derby cover leak
Good evening folks,
Bought my 98 Fat Boy in Oct/10 knowing that it had a leak from the derby cover. Assumed that it was an easy fix with a new gasket but since the bike would be sitting all winter, just got around to changing it last week. Had to order one of the 3 hole disc type gaskets from the dealer. Upon removal of the cover, I found that the old gasket (not disc type but a paper gasket) was pretty trashed. There was also a large o-ring in a channel on the inside portion of the primary. The derby cover is one of the ones that has "Harley Davidson Motor Co" in large black letters. So I re-seated the o ring and installed the new disc type gasket, put the cover on and hand tightened the bolts. Was installing my new detachable windshield tonight and had the bars turned to the right and it caused the bike to lean further to the left and after a while I noticed a puddle of oil on the floor so it's still leaking.... Don't think I over tightened them but is it possible that I still didn't tighten them enough? Should I have removed the o-ring all together?
Any suggestions are appreciated!
Thanks
John
Old 04-06-2011, 10:31 PM
Havoc88's Avatar
Havoc88
Havoc88 is offline
I may be wrong but if memmory serves thats an either or, gasket or o-ring... not both
Old 04-06-2011, 10:36 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
You need to buy the parts and service manuals.
Old 04-06-2011, 10:47 PM
oldbiker771's Avatar
oldbiker771
oldbiker771 is offline
O-ring for your year model against a flat derby cover. If non-stock derby is not flat, will leak. NO gasket on your year model. All three screws have an o-ring as well, on the outside.
Old 04-06-2011, 10:56 PM
mtnlvr's Avatar
mtnlvr
mtnlvr is offline
As Havoc said...it either the o-ring OR the gasket (frisbee style).
Chance are you now need a new derby cover as yours is likely tweaked from over tightening. Pull it off and lay the sealing surface on a fairly flat surface and check for warpage. A little warp will seal, but too much and you get the leak. It is possible to get it flat enough for the gasket to seal if you just tighten the screws enough. If warped beyond just a little, the o-ring will never seal it.
If you can't get the gasket to seal you'll need a new derby cover. If you get the type that has a wide sealing surface I'd recommend sealing with the o-ring. The o-ring is more forgiving to over tightening of the screws without warping the derby cover.
The problem that I have with the gasket is that you have to be extremely careful about not torquing the screws too much. If so, you end up with a warped derby cover.
Old 04-07-2011, 08:07 AM
perpulreaper's Avatar
perpulreaper
perpulreaper is offline
I put an aftermarket primary cover on mine and had I hell of a time getting it to seal put two gaskets together with rtv and haven't had a leak yet
TomM60 (07-16-2017)
Old 04-07-2011, 11:00 AM
#1rocketman's Avatar
#1rocketman
#1rocketman is offline
I'm a little confused over the 2 different gaskets there.My 98 only has the rubber O ring.Last winter when I changed the fluids,I had a hard time getting it sealed.I finally added just a tad of gasket sealer to help hold the O ring in place,carefully put the cover on ,tightened,and all was ok after that. Look at that O ring carefully,if the cover was put on and the O ring slipped out of the groove,it may have flat spotted the O ring enough to let fluid leak out at that spot.
Old 04-07-2011, 11:05 AM
Mike T's Avatar
Mike T
Mike T is offline
I worried with my derby cover for years leaking. I left the o-ring on with the gasket on top of it. Problem leak stopped.
Old 04-07-2011, 11:17 AM
#1rocketman
Like I said Mike,mine never had a "gasket",just the O ring,what's it look like?
Old 04-07-2011, 11:42 AM
Mike T's Avatar
Mike T
Mike T is offline
It's a gasket the Harley shop sells now that's the same size as the inside cover. You can only use it one time. I guess the reason the TC's went to the 5 hole cover was all the trouble the evo guys have with that derby cover leaking.
Quick Reply: Help with derby cover leak
