Help with removing starter from 1999 fatboy
My starter is making a ginding noise it starts but sounds like rocks rolling around when you hit the button. I have pulled the primary all looks good in there. I have gotten the jackshaft loose. I have gotten the mounting bolts out. Do I have to remove the oil tank to be able to do this. the manual says you may have to loosen them but I haven't really been able to do anything with them loosened either. HOw do I get this thing out the side of the bike? Looks like the cables are my only problem now. Please help.
on mine if i take all the tank bolts out & zip-tie (get long ones from work) the tank tight to the frame under the seat it'll buy me about 1/4-1/2" ....just enough room to wiggle the ba$tard out. if i dont get the tank tight to the frame & its just loose.....she aint coming out for nobody
Hope this helps
Hope this helps
Hope this helps
Hope this helps
extremeshot
General Topics/Tech Tips
22
02-18-2023 08:06 AM
Jackie Paper
09-22-2011 11:07 AM
