Total Oil Change
RE: Total Oil Change
I noticed you're getting no replies to your question so I'll submit my opinion:
I've never considered using it just because I am in the habit of changing my oil every 1500 miles and I have no need for sucking out the last few drops from the crank case. I think if you change your oil on a regular basis there's no need for some gizmo designed to be a money maker for the creator. Oils life is supposedly 3,000 miles if you do not expose it to extreme heat (i.e. riding when it's 100 degrees). If I do ride in extreme heat then I would get an oil cooler or change the oil more often than the recommended 3000 miles.
There's my opinion.
There's my opinion.
I realise the benefits of changeing the oil regularly but when all the oil isn't replaced then the new oil is always contaminated,which is what you are trying to avoid by changeing the oil early anyway.I have noticed quite a few of the guys running Tin Cans use the total oil chage kits on their bikes,was just interested in how many guys have tried one on their EVO.I have ordered one anyway.I run Redline oils and it is $25 per Qt.down here in Australia so anything I can used that will lower oil contamination sounds good to me.Not to mention that the temp here quite often runs over 100 deg. means that the oil needs all the help it can get.
[IMG]local://upfiles/7663/DA07E7000E9A423CA1B84D691B53C296.jpg[/IMG]
That's some expensive oil dude! Are most things more expensive down under?
For a situation as you described or living in any high temp. areas I guess it wouldn't be a bad idea to use a scavenger. I don't think the oil contamination is all that bad if the engine is warmed up before an oil change as recommended in the service manual. Warm oil flows faster and you'll get more oil out of the engine than doing a cold oil change, however not as much as you would using a scavenger. I would like to know how much oil is left in the engine after "all the oil" is drained using the conventional method. Could you let us know?
Another opinion
Another opinion
ORIGINAL: RudeDog
ORIGINAL: RudeDog
Another opinion
Another opinion
[IMG]local://upfiles/7663/1B644F6599DB442486ACC42533FBC7E8.jpg[/IMG]
ORIGINAL: danbo
As much as 24 ounces of dirty oil remains in the bottom of dry sump harley engines . I think it is a good idea on any engine to purge the old oil out of the engine. Why settle for a little (almost a quart) of old oil with acids and fuel in it when you could have clean oil completely. It's like the guys that want to save $3 on a filter by using an off brand. Why not just get the black HD filter and save there but know it was designed for the engine.
ORIGINAL: RudeDog
cheers
[IMG]local://upfiles/7663/0915153165ED435791D028EAB32D0DBB.jpg[/IMG]
I checked out the Rogue Chopper site. Their product seems to be a decent idea if you want to purge your system of old oil. If I was gonna do that, I'd probably run a few quarts of the new oil through the setup, re-drain the oil pan/bag. Then fill anew before installing the filter. Remember, on the EVO oiling system, the last stop before the tank/pan is the filter.
