Still trying to solve 85 FLT oil line problem
Old 07-12-2011, 02:19 PM
Cupo's Avatar
Cupo
Cupo is offline
6th Gear
Unhappy Still trying to solve 85 FLT oil line problem
I bought the bike with a damaged front end. It was delivered on a skid , it started fine, oil pressure came up. Replaced the air ride front end, came time to take it off the skid. It had boards shimmed up underneath it so to get it off the skid I had to tap the boards out. Got the front wheel on the ground and them noticed that the hose that runs next to the oil pump (from the crankcase, then goes over the engine, between the barrels and down under the engine and the inner primary cover) was off and oil was coming out. Now I know someone will say go to the manual diagrams. I have three diagrams. One shows me that it is a square oil tank, but this one is a V shape under the side cover. Another diagram shows it's a dead line and should be plugged. Another says it is a return, but my issue is that all the diagrams eliminate the oil filter.. So if anyone has this bike and can check the routing of this oil line please let me know where it goes.. I don't have a table or jacks to lift this bike high enough to check under it better, tried the mirror, still can't see anything!
Old 07-12-2011, 02:29 PM
bubba4u's Avatar
bubba4u
bubba4u is offline
i think that model has a self-oiling primary, check and see if you have a line running in and out of the inter primary at the bottom between engine and trans
Old 07-12-2011, 02:31 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
There is no hose that runs over the engine, between the cylinders and down under the engine.
There is a hose that runs from the engine block at the back medial to and below, I think, the oil pump to (originally) the air cleaner. Most people re-route that down under the bike, but not through the cylinder V. Oil will come out of that if the bike has sat for a while. Some do it more than others. You need a proper oil line diagram for a "bottom breather" bike.
Late '84-up did not have a dry primary, so no oil feed to the primary.
Old 07-12-2011, 02:33 PM
bubba4u's Avatar
bubba4u
bubba4u is offline
it may be the beathing line, the older models, if they set up a while, will blow oil though that line when you frist start them up
Old 07-12-2011, 03:17 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
We need someone with the correct factory service manual to chip in!
Old 07-12-2011, 03:38 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
I did, Graham.
Old 07-12-2011, 04:15 PM
robertl's Avatar
robertl
robertl is offline
sounds like transmission vent hose. should be a L fitting on top left of trans.check it out.
Old 07-12-2011, 04:56 PM
bagga's Avatar
bagga
bagga is offline
there's an oil line diagram on the inside of the cover that goes over the oil tank. it sounds like the breather hose to me. where is the hose in question attached to the motor?
Old 07-12-2011, 05:10 PM
ajayrk's Avatar
ajayrk
ajayrk is offline
Maybe this will help. The oil filter is shown as a dotted line behind engine.
Attached Thumbnails Still trying to solve 85 FLT oil line problem-oillinescrop97-529x379-.jpg
Old 07-12-2011, 05:53 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Except, ajayrk, that pic is early 84 and his is 85. No primary chain oiler.
Quick Reply: Still trying to solve 85 FLT oil line problem
