Replaced Lifters and Rods
Just replaced the rods and lifters with vThunder lifters and SE EZ install rods. I got rid of the major noise that was coming from a lifter with a bad roller on it, but I still have a little noise in there that comes and goes. I've only got about 20 miles on it since the swap, but is there some sort of break in period for these until they quiet down? Running an EV-27 cam.
I have an EV-27 in my bike and have valve train noise ,that is not uncommen. If you do not have the correct end play in your cam the thrust washer will make some weired cam noises. Andrew recomends .010-.015 end play in the EV-27. you will have to shim the cam with a .050-.060 cam shim. You would be supprised on how many people just put the cam in with out checking end play . O one other thing make sure you change the inner cam bearing to a Torrington bearing .
The higher lift you go, the more valve train noise you'll have with an Evo. This is due to the valve train geometry, just look at the angles of your push rod tubes. That's probably the only major improvement of a Twinkie over an Evo.
However, at the same engine speed and operating temperature, the amount of noise should be pretty consistent. As stated before, I would check your cam end play if the amount of noise changes for no reason at all.
