Fxlr tank strap
Fxlr tank strap
I am having my tank resprayed on my 93 FXLR.
The leather tank strap is fixed to the front tab by 2 crappy bolts and cross head screws.
These have been replaced by hand made stainless fixings( i have a great engineering friend)
The rear of the strap was held on by 3 tie wraps.
I think it should have some kind of elastic fixing, but not sure.
I will be putting the strap back on the tank, any ideas how to fix the rear end on it ?
Dee.
Dee.
I see you're not having much luck. You might be right, go to a sewing store, get some suitable elastic, drill and tap a hole, bolt and washer and you're good to go. Having a hard time visualizing what you're up against. obviously not stock if it had zip ties. sooner or later you'll find something that works Trial and error.
