Broke down....
Broke down....
Took off for a nice ride....everything working fine. Went about 200 miles and about five miles from home....and the bike just quits. Check engine light came on when it died.
I quickly discovered the small 15 amp fuse was blown under the right side side cover. Replaced the fuse and the bike started right up. Then, the fuse blew again....I think it blew when I gave it gas. When the fuse blows, it all shuts the fuel pump off.
I checked for codes already.....came up with 23, 24, and 25.
23 being the injector.....fairly new red injector, so I doubt that is a problem.
24,25 being the the coil.....very possible failure with lots of mileage and years.
I am planning on checking the coil tomorrow following the factory manual.
In the meantime....anyone have similiar problems and their EFI model?
Last time I was stranded on the Ultra.....the stator/rotor shorted out. That time I was about 20 miles from home. Been stranded on the Low Rider about one mile from a HD dealer when the belt broke....HD didn't have the belt in stock either.
I've been stranded other times in the past......but have always been able to figure it out on the road.
According to the book....If the fuse is blown, a short to ground is present between the fuse and fuel pump relay, between the fuel pump relay and fuel pump, coil or injectors, or the fuel pump itself may be the cause.
I've already checked for codes....23 front injector, and 24/25 coil. Both are mentioned in why the fuel pump fuse may be blowing.
The only fuel problems I've had.....since I upgraded to Stage 2. I could be riding at 70-75 mph in fith gear. Give it full throttle....speed does not increase giving a feeling that it is bogging down. It does not do that all the time......just sometimes.
Everything in the tank is original and has never been replaced with the exception of the fuel gauge sending unit a couple years ago.
I sure am hoping someone here has had this problem.....cut down on the troubleshooting time. Just go directly to the problem and fix......
Little update....started investigating....
I first replaced the fuel pump fuse with the new one....started right up just like nothing ever happened. Could not make it do the same thing again....
Per the manual....everything regarding the fuel pump plus the wiring checked out ok. Fuse to relay was fine, relay to pump was fine, and pump was fine....all checked the contnuity check.
While I was in the tank....I figured I would check the filter as well for the issue I would have at 70+ mph when the speed would not increase. Anyways, the filter was full of brown crud. I'll get a new one on order soon....
Not checked the coil just yet since it is buried under the tank. Didn't feel like removing it! Before I go checking the coil, could a coil overheat and blow a fuse? The bike was cold from sitting all night....new fuse in and no problems. Possibly heat related? Ideas?
I maynot be able to mess with it again till Wednesday or Thursday.....
Unfortunately, any part of that circuit could be causing the problem. Or a bare wire shorting to ground. I doubt, though, that a coil could cause it. The coil usually only has a couple ohms resistance anyway. I would be more suspicious of the fuel pump than the coil. What is the story on the injectors? Do you have the old ones? You might try swapping them out.
Intermittent problems are a biatch to track down. You have to wait until the problem is showing itself, then start measuring everything in that circuit and look for something shorting internally or to ground. I'd help you out, but Russellville is far away from Fay.
