Best Battery Cables
Received 4,317 Likes
I'm guessing from another post that the factory cables are 8 guage? What gauge wire did the starter manufacturer recommend?
Aftermarket cables would only have better conductance if you're going to a larger diameter cable. But, with the upgraded starter it makes sense now why you're interested in upgrading the cables.
Actually conductance is affected by both size of wire and materials used in construction of the wire. (All materials have an inherent resistance it is just some materials are less resistant than others.) It is possible to have 2 different wires with the same gauge with different conductivity. That said I don't remember what gauge wires I got to replace the stock ones but they looked pretty much the same. The construction process was differant though.
Actually a little more than diameter comes into play. Just to use some numbers lets say the stock cable has 30 strands of copper wire, and the aftermarket has 60 strands of smaller wire in the same final gauge (lets say 8 gauge for the sake of this example). If you look at the cross section of both you would see more air space in the 30 strand than in the 60 strand. As we all know copper conducts electricity, not air. With more conducters you have the ability for more power to the starter in this case. Also the ends are usually better and affixed to the cable as well, again this allows more power to be available. Hope this helps.
