Best bike lift
Found the Harbor Freight full lift for $289 that has been dependable for it's needs. Please don't take this personal, I treasure my bike #2 behind my family but wouldn't be able to sleep at night with a bike being held in the air by some of these jacks and usually a no fear type of guy but opening a door and the White Bike laying on the floor is a picture that I try to keep out of my head. Like I mentioned, view not directed towards anyone owning a listed jack just a little chickenchit coming out.
Received 4,317 Likes
Granted I bought a HF jack when I first got my bike but that was because it was all I could afford at the time.
I bought a J&S just as quick as I could and it is definitely worth the money IMO.
tar_snake (08-26-2017)
Received 14,172 Likes
Received 4,614 Likes
The Harbor Freight hi-lift is a great jack, but it has some issues that might make it unsuitable for some folks if it's their only jack. It doesn't move with a bike on it; once you pull the wheels, the bike and jack stay where they are till you put the wheels back on. It has two stop positions, holes in the jack a large pin goes through. While you're jacking it, there are no incremental stops to catch the bike if something goes wrong. I don't worry about this, very unlikely, and I have had a bottle blow a seal with a bike on it. It just settled down real slow - till it hit one of those stops. Was that ever fun getting the bike off a stuck jack with the wheels in the air.
Positives - don't have to worry about the bike tipping over; you can pull a wheel and it won't try tipping the jack over. It goes high, over 30", and I found that to be great for my old back, being able to sit on a stool and have a clutch change at a comfortable height.
Apparently another negative - it's blue in that pic, and evidently blue is a more expensive color...
Don't care what kind of jack you get, if it isn't tied down, it can tip off a jack, kids and dogs have proven that. Tied down properly, the bike won't tip off the jack, but you can still have a jack go over sideways if you take too much weight off just one end of the bike; that's easy enough to compensate for if you think about it.
I have a frame with a motor in it on a jack this winter, need to roll it out of the way occasionally, but it's down off the bottle, too. I wouldn't leave anything sitting even overnight with just a bottle holding it, but all these jacks have stops that will hold the bike at various heights with no hydraulic pressure.
Nothing wrong with having a couple. I've had a jack situation come up when a bike was on a jack already; handy to have another one then. I use the HF hi-lift most of the time, but other times want one that can move the bike around. I'd really like a table lift, too, just don't have the room.
Kinda scary the first time you lift one all the way up. And the second time... third time...
