1986 FLHT Rebuild
If you want to put some good money into her, do a thorough top end, heads and cylinders, lifters. Make sure wheel bearings have been serviced, inspect the belt, check rubber, change all 3 holes, a/c, lube cables, check the voes hose for cracks, pipes at the cross over for cracks.
Your bike actually looks pretty clean, have you done a compression and leak down test?
ramx50
Dyno Charts
08-20-2018 12:41 AM
